Home > Maintenance & Modifications > Installing a working light
burke46
Ireland 2007 Defender 90 Puma 2.4 HT Barolo Black
I plan on installing a Wipac working light on the rear of my defender. The light has a built in switch so I am going to wire it with a fuse to the purple speaker wire. I am wondering what is the best way to drill the mounting holes so the paint isn't damaged and what are the best sealing options for the mounting and wire holes.
Post #698566 4th Apr 2018 5:57pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Be careful just connecting to a wire in the rear speaker box if the light is halogen bulb. If the bracket is similar to the Lucas oem work light then the bracket is folded in a way to allow the cable to be tucked underneath and concealed under the bracket so as to help prevent water ingress.
Post #698589 4th Apr 2018 6:54pm
LR90XS2011
i did this, little low but no holes in bodywork
 DEFENDER 90 TDCI XS,
Post #698602 4th Apr 2018 7:45pm
