Home > Puma (Tdci) > Traction control? |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
Did you notice any spining up of the tyres at all? It only lights up when it's actually in operation, so maybe it wasn't needed.
Chris. |
25th Mar 2011 4:51am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Depends what model it is, county spec didn't have ABS or traction as standard it had to be specified. Lock up the brakes on some grass and see if you have ABS is a quick way of telling.....................Oh and leave some foxes for the hounds Original Member Pie n Pea Club.
110 HCPU Tipper |
25th Mar 2011 7:27am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
If it has TC (and ABS) the quickest way of telling is seeing what lights come on when you put your key to PII - you should have the ABS and the Tyre symbol in yellow Mike
25th Mar 2011 9:08am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Or perhaps you are a demon driver and automatically drove where you could find traction so the Tallent Controll was not required 130's have feeling's as well you know |
25th Mar 2011 9:17am |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 |
Thanks for the positives (talented driver) but it doesn't have TC or ABS its only the XS model that has all this unless it's been specified.
willy eckerslike left you some foxes. |
25th Mar 2011 4:52pm |
