![]() | Home > Puma (Tdci) > Accessory Socket |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
its in the dash normally with a cigarette lighter in it DEFENDER 90 TDCI XS,
wiring go too driver side rear next to back door, no Accessory Socket fitted
have read of post below http://www.defender2.net/forum/topic20319.html |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
The cigar lighter is fuse F26 in Secondary Fuse Box!! Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
As Dorset smith says above, it's for the optional socket location in the back. The wiring will be there, it's not difficult to add a socket there if you want one.
Thanks dorsetsmith and zsd-puma thats very helpful. Discovery 4 HSE
Sorry
there is a thread on here regards the rear socket install and from memory a purple wire behind the rear speaker housing titled "Installing a aux power socket in the rear" done it myself quite easy http://www.defender2.net/forum/topic20319.html?highlight=purple ![]() Click image to enlarge ![]() Click image to enlarge DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
