Home > Maintenance & Modifications > Door Aperture Adjustment on SW/DCPU
rallysteve
Having rebuilt several 2/3dr defenders I have previously set the aperture for the front doors by shimming the bulkhead once the tub is correctly set.
However, the door gaps on my current DCPU (front and back side doors) are too much, so i could do with adjusting. However I have never messed with 4/5dr side panels and cant see how the door gaps can actually be adjusted. The tub position is fixed and the bulkhead can be shimmed back, however as the B-Pillar is fixed onto the sill, moving the bulkhead will presumably move the b pillar back too? How can you reduce the door apertures on these?
Post #696708 28th Mar 2018 12:43pm
