![]() | Home > Puma (Tdci) > Steering column |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
Part number for a Puma is QME500270.
Everything you say about TD5 and Puma parts is correct , the heatshield is fitted due to the proximity of the shaft to the exhaust and cat on the RHD vehicle. TD5 part number is QME500031. |
| RichieRich Member Since: 07 Jul 2013 Location: Cape Verde Posts: 36
Thanks Blackwolf, very much appreciated. As I’ve got a left hand drive defender I’m good to go with the TD5 part? Do I need to order a LHD specific steering assay? Sorry if that’s a dumb question just want to make sure! Anything else I should be changing? Thanks again.
I doubt that there is a LHD/RHD difference, but it would be sensible to check an online parts listing.
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
Just a question. Are you sure it’s the lower steering column?
Because I’ve never heard that the steering column is the culprit. Normally when you’re having some play in the steering it’s the steering box you need to replace. a defender from 1984 pretending to be a puma with a touch of Range Rover |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Or drop arm balljoint
They do wear, although it is not a particularly common problem. The easiest way to check is to put your hand firmly over the UJ on the shaft you want to check and get an assistant (unless you have very long arms when you can do it yourself) to rock the steering wheel. You will immediately feel any movement.
| All times are GMT |
