![]() | Home > Technical > Crabbing |
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
As a first step, it might be worth making a quick geometry check, just park up on a level surface and make a chalk mark on the ground at the centre of each wheel, then move the car and measure the distances diagonally.
I don't know what the tolerance is but it might at least give you a clue where to look further. |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
Get another person to follow you to confirm you wouldn’t notice much from driving seat
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
I once worked on a brand new Rangey (L322), belonged to a company that sells very expensive Defenders...
It needed an airbag sensor, which is buried down under the centre console, which meant it had a crash at some point. Out of curiosity we measured the wheelbase, it was only 2.5 inches shorter on one side!!! QRZ M8VPF |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Have you lifted your Defender? If so and this is esspecially the case in bigger lifts, it can cause crabbing as it pulls the front axle out of alignment with the rear axle. The culprit is the panhard rod being too short. Solved by fitting an extendable version.
If not lifted then I would be looking at the bushes, especially the radius arm and pan hard rod bushes. Slop in these can also cause the axles to shiuft out of alignement. |
| All times are GMT |
