Home > Technical > Defender Steering Box Drop Arm Lock Nut
Harry.O
Does anyone know the correct part number for the locking washer that secures the drop arm nut to the steering box?
I've found 2 so far, AEU4025 which has 2 tabs on it and 600265 which is just a 48mm washer but I'm away from the vehicle so can't check which is fitted. It's a 2005 Td5 110.
Thanks in advance, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #692593 11th Mar 2018 12:38pm
rallysteve
Did one the other week, the one that came off the 98' 110 was the one with two tabs. Refitted with the 48mm washer though. The nut shouldnt come lopse with the torque it is meant to be tightened to!
Post #692595 11th Mar 2018 1:01pm
Harry.O
Thanks Rallysteve, I'll get one of the round ones ordered Very Happy 176nm does seem rather tight! 2005 Td5 110 Hardtop
Post #692600 11th Mar 2018 2:08pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I have seen a couple of them come loose over the years, both times the locking washer wasn’t correctly tabbed over. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #692665 11th Mar 2018 8:18pm
jst
You do need it, have seen plenty where the nut has come loose. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #692748 12th Mar 2018 7:10am
Harry.O
The locknut on my old 90 also came loose some years back so when I convert the 110 to the disco style drop-arm, I'll fit a new lock washer for peace of mind.
Whilst having a shufti on Google last night, there's also a 3rd version (STC874) which again is a large washer but 60mm rather than 48mm. This was fitted to late D1s that use the droparm with a hole for a TRE rather than the Defender style ball joint. 2005 Td5 110 Hardtop
Post #692893 12th Mar 2018 6:37pm
