Home > Technical > Turbo Problem 2.4 Puma |
Mike 1944 Member Since: 05 Mar 2018 Location: Johannesburg Posts: 2 |
Clutch replaced 6 weeks ago by Overland Worx in Johannesburg at 140 000 km. Pressure plate was intermittently sticking on spline and not releasing!!!
Repair ok but heat coming from tunnel covering gearbox seemed a lot warmer than before. Reported to Overland Worx but they seemed unconcerned. Have just done a 1200 km round trip and at 300 km while driving at a steady 100 kph the motor seemed to loose power. ( as if I was braking while leaving my foot on the accelerator) Immediately stopped and switched off ignition (no management warning light had come on). Opened bonnet but could see nothing wrong (except tunnel covering being very warm - driving in shorts it was uncomfortable if your knee touched the tunnel). All ok when I got back in and carried on with the rest of the journey down to the coast. On my return yesterday the problem came back after about 50 km of driving. Although stopped it did correct itself but did not take long to loose power again. Was now aware that it was a turbo problem and I looked carefully at all connections and piping but did not remove the heat shield covering the turbo, Limped the rest of the journey home with the the turbo occasionally kicking in and even sometimes hunting. Any suggestions before I take the vehicle back to Overland Worx here in Johannesburg. |
6th Mar 2018 6:18am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
faulty loom - extended loom available where it stretches over the aircon compressor
Sticky turbo vanes - get some spray through the inlet When it goes again, dont switch off, open the bonnet and watch while someone revs it up, see if the acuator moves on the turbo, then get them to switch off and see if it resets itself good luck |
6th Mar 2018 7:33pm |
No management light came on. Booked in with them for tomorrow Thanks
11th Mar 2018 4:35pm |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 437 |
I had a similar problem which turned out to be a turbo with sticky vanes. You can look at the actuator and see whether it’s up or down. When it’s cold you can take the little circlip off and move it up and down manually. It should be really easy to move. Mine was fine when it was cold of warm but on a long run it would start playing up
13th Mar 2018 6:25pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
The more problems the marrier.
Can be loom Can be vanes Can be actuator Or you have a temp problem - pel mod - nakatanga nut - bigger radiator Or in my Case 4 out of 4 Oh forgot split turbo hose a defender from 1984 pretending to be a puma with a touch of Range Rover |
13th Mar 2018 6:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19652 |
Split Turbo hose, is one commonly missed.
Easy to overlook. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
13th Mar 2018 6:43pm |
