Home > Maintenance & Modifications > Side Step Woes
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Side Step Woes
Looking for ideas / inspiration. I have side steps like the ones in the picture below.
The problem is that I have a 2" lift and these sit a whisker below the cill. It turns out that this is not low enough for the Mrs to get in without 1. Slipping 2. Shinning herself 3. Ripping my head off for the pointless Censored stupid steps.
The good thing about them is that they do protect the sides of the car from supermarket numpty abuse.
What are sensible options for lower side steps. I'm guessing that I need them 2" or so lower than they are now.
I really like the original fold down ones for classic looks but they would leave the sides susceptable to the supermarket numpties. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #690293 2nd Mar 2018 7:03pm
Sockpuppet
Get some 2 inch blocks of alu and drill some holes in them to lower the steps by 2 inches.
Post #690294 2nd Mar 2018 7:04pm
300TDi CSW Phil
Although that is a nice idea as it should be relatively cheap. I'm not sure how well it would work as these only bolt at the front and rear ends to the outriggers. I think the otherhalf might prefer flat top steps as well. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #690295 2nd Mar 2018 7:09pm
VeeTee
Netherlands
I have a seperate step for when the Mrs has to climb aboard Laughing
 Cheers, Vincent
MySite
Post #690309 2nd Mar 2018 8:00pm
300TDi CSW Phil
Now that looks like a good idea.
Tree sliders to protect from supermarket numpties and a lower step.
Now to get my engineering head on to see if there is a way of securing the step to a tree slider for normal use which is easy enough to remove for the odd bit of greenlaning. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #690317 2nd Mar 2018 8:12pm
VeeTee
Netherlands
The step slides on the tree/rockslider, I use it only if the Mrs is coming along, it is put on or taken of in a second... the picture in the other post is from the manufacturer Quadratrec where I bought it from. This the step on my vehicle:
 Cheers, Vincent
MySite
Post #690321 2nd Mar 2018 8:25pm
donmacn
Bumpitty bump...
Did you resolve this Phil? What did you go for in the end? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #744134 5th Dec 2018 9:43am
jst
fit standard springs..... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #744136 5th Dec 2018 9:48am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Your side steps look like mine which are Terrafirma no space between them and the sill. My wife seems to manage OK though. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #744141 5th Dec 2018 11:01am
300TDi CSW Phil
So far the solution is earplugs Rolling with laughter that way I can't hear her moaning about it and as I have a few hundred pairs left from my motorcycling days it's effectively free Thumbs Up 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #744142 5th Dec 2018 11:02am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
You just need a bigger Mrs. Problem solved Whistle
Post #744151 5th Dec 2018 11:41am
300TDi CSW Phil
She's nearly 5'10" same as me, just doesn't seem to have the bounce to get up into the Defender. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #744160 5th Dec 2018 12:07pm
donmacn
Rolling with laughter well, this bump has raised a smile or two!
I'm just asking because I like the idea of the additional strength offered by the sills; but can anticipate the gripes and groans about losing the original fold-down steps. Donald
in the past..
Post #744166 5th Dec 2018 1:06pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
My wife has arthritis and finds it hard to pull herself up into the motor. Even at the standard height as the step is very shallow.
I have now taken off the tubular step and put standard fold-down steps on her side and kept the tubular step on my side which, as you cannot see both sides of the motor at the same time, does not look too odd. Also keeping the steps folded down affords some protection on the n/s.
Post #744303 6th Dec 2018 7:50am
300TDi CSW Phil
donmacn wrote:
Bumpitty bump...
It's taken a while but yes.
A change of misses Rolling with laughter 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #915942 7th Aug 2021 5:53pm
