Home > Maintenance & Modifications > 110 DCPU Rear Seat Options
bankz5152
Really don't seem to be a lot of options available for a DCPU! I did originally want two Exmoor high backs but recently found out they arnt child seat compatible and apparently not comfortable either, so thats out.
The other set of Exmoors are £600 each and not too sure how the fit in place. Anyone got them? Pics/thoughts?
Puma rear seats is what I'd like but looks like they require too much work to properly fit and will end up costing the same as the pricey Exmoors.
I've seen L322 rear seats in the back which looks good and fit but I expect still more cramped and a lot of fabrication needed.
Only other option I could think of, which I have seen done. Is modifying the existing seat frame to accept Defender front seats. I'd have two front seats and a normal middle seal. Any one got any pics or experience doing this?
Anyone got any other ideas? Got to be comfy, have headrests, be child seat compatible and ideally black vinyl/leather.
Thanks Smile
Post #690051 1st Mar 2018 8:25pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
There is a lad local to me who has fitted 4 x Recaros to his dcpu
With two cubbys, one between the front & one between the rear two seats
If I catch him in the near future I will ask to take a snap
(I know it’s nit what you are after , but maybe inspiration) My confidence has been writing cheques that my abilities can't cash for years.
Post #690086 1st Mar 2018 9:46pm
bankz5152
That would be brilliant if you could, I may go for buckets but not sure yet!
Post #690105 1st Mar 2018 10:37pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
My DCPU has the Exmoor High Backs in black leather and I wouldn't want to sit in them for long. I'm wanting to remove the middle one but at first glance it looks as though the outer seats rely on it for support Sad They came with the truck but I would've been disappointed if I'd bought them as an upgrade.
Post #690114 1st Mar 2018 11:13pm
bankz5152
Good to know, thank you. Can put that option out 100% now. Makes you wonder why they made them like that? Haha
Post #690117 1st Mar 2018 11:20pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Ah well, you’d also wonder why Land Rover put the standard Puma rear seats in a dcpu. They are simply too large.
I’m everything but tall. My head rests on the headliner instead of the headrest and I always have the feeling I’m sitting a bit face down. Also don’t have a nice view out of the window.
In my other 130 I had them replaced by a custom made seat box with the right angle and height. Put two front seats in it. Every problem solved!
Post #690128 2nd Mar 2018 1:07am
In a word, cost.
Post #690142 2nd Mar 2018 7:58am
bankz5152
Pics?
Post #690155 2nd Mar 2018 9:25am
tookaphotoof
You can have a look at the complete project here: http://www.defender2.net/forum/topic22936.html
With the 110 dcpu you just need a slightly different seatbase. Idea will be the same.
Post #690185 2nd Mar 2018 11:14am
Grenadier
I already have a pair in the front and have considered a 4-seat configuration. I'd be interested as well, but actually if you could try them and see how upright they are and how much leg-room there is. There are quite a few photos of upgrades done by various bodyshops, but you never get a sense of the seat-back angle or leg space. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #690222 2nd Mar 2018 2:08pm
bankz5152
That looks stunning. Though how did you secure the seatbox to the landy?
Post #690912 4th Mar 2018 7:21pm
Grenadier
Read this thread with interest. Can you clarify that no mod was made to the cabin? If so, is it the use of front seats and the new seat box that gives more leg-room/lean angle? Are rear seats thicker? Would the same extra level of comfort be achieved with Recaros if your seat box design was used? Monsieur Le Grenadier
Post #691109 5th Mar 2018 11:19am
rallysteve
It is worth mentioning that the scope for modifying the rear seat box is more limited on a 110 than it is on a 130 due to the chassis member for the rear A-frame beneath. Hence why the 130 has storage in the seatbox and the 110 does not.
Post #691112 5th Mar 2018 11:22am
Grenadier
Good to know. Ta.
I'm not too fussed about extra leg-room, we don't have kids and Mrs Gren and I have little legs, so front recaros are pulled forward. But I want the rear to be co,ofrtable for up to an hour, which is about as far as we drive locally when friends pop over, and most remark how upright the current seats are. So any opportunity to add an extra bit of lean would be welcome. Hence wondering if it could be achieved with Recaros? Monsieur Le Grenadier
Post #691113 5th Mar 2018 11:31am
tookaphotoof
Grenadier, that’s correct. The new seat box was designed to be fixed with the exact mounting holes from the old seat box as well. The standard rear seat is just too bulky by design. Land Rover shouldn’t have used it in the rear of a double cab if you ask me.
Post #691116 5th Mar 2018 11:38am
