![]() | Home > Td5 > Td5 undertray |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Went to search for an intermittent oil leak and checked the workshop manual for removal of the undershield,.....since it would’t slide out after removing bolts.
Seriously? You need to disconnect the front drive shaft to remove the plastic under tray? Is there a modification to make them more easily removed when needed? Patrick |
I seem to remember (before I threw mine away) if you can jack the front up high enough so both wheels can drop fully on the suspension, then you can wiggle the tray out. It's not too hard if you have a lift but can be done on stands. Ray
Day 1 of TD5 ownership - Grin like a bafoon...
Day 2 of TD5 ownership - Get rid of under tray on eBay. ![]() ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
What plastic undertray
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Yes what undertray, nothing under my 2000 W reg!
What does it look like? |
Probably covered in oil
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 241 ![]() ![]() |
Nothing here on my 04 either, should there be.. I’ve never seen one on any td5 I’ve looked at?
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 874 ![]() ![]() ![]() |
No undertray on my 05 110
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
In pretty sure it was standard on XS and optional on county models
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Got it on my 04 non county S/W.
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I'm fairly sure they were fitted on all Td5's from new, something to do with "drive-by noise" regulations, soon got left off after an oil change or wiped out while off-roading though.
Possibly all station wagon variants but I know for a fact that my pickup didn't come with one from the factory
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Mine had one. I think some elements of it remain, some are possibly in a puddle on Salisbury plain...
All the fixing bolts are still there but the tray slowly disintegrated over the first couple of months of ownership. For a while I did have a short branch wedged in the gearbox crossmember holding it in place before the next trip to a Pay and Play site. That was the day it got put in the back
