Home > Puma (Tdci) > EGR switch off without blanking plate?
Page 2 of 2 <12
daftlad
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Are 4 and 3 the same size chaps
Post #688566 24th Feb 2018 10:05am
dgardel
Italy
My EGR is closed by map since 2009 and never installed the plate. No problem at all.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #688742 25th Feb 2018 10:44am
agentmulder
Kuwait
Have you tried driving without the map at all? Solved the bowel problem, working on the consonants...
Post #688747 25th Feb 2018 10:59am
zsd-puma
Nope.
Post #688797 25th Feb 2018 4:49pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Had my EGR switched off today.
Why didn’t I do it sooner!? Felt smoother from the moment I pulled away and It’s never felt so good.
Blank is on order so will fit that when I get a chance.
Thanks for all the opinions and information everyone Bow down My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #689148 26th Feb 2018 10:50pm
meeerrrk
agentmulder wrote:
I took my map off temporarily and the valve stuck open giving me effectively limp mode 2 minutes in to a drive. All fixed now and I have the plate, but just need some spare time to install it.
So if you're splitting a joint there's no new gasket required on both sides of the plate?? I don't have my vehicle available but is it # 3, 4 or 5 ? Looking at it my guess is 3, but I'm not sure which direction the gas is flowing.. Embarassed
the blank I have purchased goes in position 4 in your diagram, sorry for the confusion! My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #689223 27th Feb 2018 10:49am
Page 2 of 2 <12
