Home > In Car Electronics > Alarm
mk1collector
Alarm
I've looked around the net but can't find an answer to this one. I've recently added a new alarm fob to my td5 which works fine but tonight I noticed that when I now lock the defender the indicators flash 4 times and not 3 Confused I'm not sure if this has happened for the last couple of days since adding the new fob or if it's just started tonight but on the old fob it only flashed 3 times. I'm going to check what the old fob does tomorrow but in the mean time Does anyone know what 4 flashes means before I go further?
Ray Ray
My build thread
Post #687504 19th Feb 2018 12:46am
mk1collector
Ok I've tried the old and new fob this morning. Using the old fob, unlock flashes once and lock flashes three times and using the new fob, unlock flashes twice and lock flashes four times Shocked is this normal or do I have a problem? I can't find any mention of different amount of flashes anywhere other than not flashing if the fob battery is low or door switches not working. I think I'm going to go back to using the old fob until I've found out what's happening. Ray
My build thread
Post #687539 19th Feb 2018 10:03am
mk1collector
Post #687773 20th Feb 2018 10:54am
discomog
I think you've got everyone stumped on this one. Embarassed Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #687790 20th Feb 2018 12:17pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Can you go through checking all is working ie setting off the alarm, try to start car with fob away from ignition, locking and unlocking doors with key and seeing if alarm triggers?
Post #687794 20th Feb 2018 12:40pm
grafty99
My all in one keys do this, but my original ones don't. Nothing to worry about Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #687801 20th Feb 2018 1:01pm
mk1collector
Everything seems to work the same as my old fob so I'm guessing it's fine Confused Ray
My build thread
Post #687848 20th Feb 2018 4:39pm
mk1collector
That great thanks Thumbs Up Ray
My build thread
Post #687849 20th Feb 2018 4:39pm
