![]() | Home > Technical > Diagnostics Advice |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello rmcgill
http://www.defender2.net/forum/topic10829.html or you could just take it to a LR Dealer (or good independent... ![]() I bought a Scangauge II on my first 'dashboard illumination', a non-issue as it turned out for me, but good to be able to see for yourself. Good Luck. SKIP https://www.defender2.net/forum/topic83242.html |
rmcgill Member Since: 28 Jan 2018 Location: West Yorkshire Posts: 7 ![]() ![]() ![]() |
Thanks for tips - will consider buying one. Is it easy to fit?
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Most are not a permanent fit - just plug into the OBD port
