Home > Puma (Tdci) > Centre Console Illumination Blowing Fuse
Bluest
Can anyone offer some practical advice in tracing this fault. The dash centre console illumination is routinely blowing its 10a fuse. It will work for a time before the fuse blows. Possibly triggered by a bumpy road. I’m assume this must be caused by an exposed conductor somewhere in that circuit.
Trouble is, I’ve had the console out looked at and wiggled all the wires to avail. Can anyone offer any practical advice in tracing the fault, bearing in mind there must be 20ish individual switches and bulbs illuminated on this circuit? I’m tearing my hair out. 2007 110 TDCi Station Wagon XS
Post #686610 14th Feb 2018 6:55pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
10a seems like a lot for a few tiny bulbs, are you sure the circuit isn't shared with something else?
I haven't got a diagram to hand right now, but maybe someone else can clarify. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #686684 15th Feb 2018 7:50am
Bluest
I’ll have to check. Think I’ve got a wiring diagram somewhere. 2007 110 TDCi Station Wagon XS
Post #686688 15th Feb 2018 7:58am
Bluest
Ok, the one other thing on that circuit are the head lamp leveling motors. I know one of those doesn't work. Could that be causing the intermittent fuse blowing?
I've had the dash panel out again today to find any damaged wires, I've pulled tugged and wiggled every cable and can't cause the fuse to blow. It all look ok. 2007 110 TDCi Station Wagon XS
Post #687193 17th Feb 2018 4:26pm
ozzie1989
Yes I'd say it's more likely those. After all they and their wiring and connectors are exposed to the elements and one isn't working (could be jammed).
Each time you turn on the ignition (regardless of whether the lights are on or not) power is fed through the switch to keep the lights in that position. If you disconnected the switch the lights fall to their lowest position as that is their fail safe.
I'd get that looked at, the motor or mechanism could be jammed and could cause the motor to blow the fuse. Now: 2010 2.4 TDCi 110 Utility Wagon
Post #687264 17th Feb 2018 9:09pm
Bluest
Replaced the faulty levelling motor. Now to see if the fuse continues to blow... 2007 110 TDCi Station Wagon XS
Post #688421 23rd Feb 2018 2:28pm
