Home > Wheels & Tyres > What size?!
barrowg
United Kingdom 1990 Defender 90 200 Tdi HT Corris Grey
What size?!
Hi all,
I’m currently running a set of all terrain koala 4x4 tyres on 16inch rims, but they look too small and are affecting the speedo, they’re currently 235 70 r16, on a defender 90 1990. What size should I have to fit my speedo and what size would people recommend using for the best mileage handling etc.
Tia
George
Post #686089 12th Feb 2018 5:48pm
Mdm
what engine is in yours?
is the t box standard?
205 80 16
7.50x16
235 85 16
265 75 16
all standard lr sizes. small to tall and thin to wide.
Post #686114 12th Feb 2018 7:37pm
JOW240725
As above Thumbs Up James
Instagram @suffolk_rovers
Post #686116 12th Feb 2018 7:38pm
The size you need is either 235/85 or, possibly, 7.50 x 16 if you're using standard steel wheels.
If you're using standard LR alloys then 265/75 is also a common size.
I think the difference in mileage between the sizes would be marginal, at best. Tread pattern is likely to make more of an impact but even that won't be huge. Darren
Post #686117 12th Feb 2018 7:40pm
barrowg
205 80 16
7.50x16
235 85 16
265 75 16
I have a 1990 200tdi with the lt77 gear box if that helps?
Post #686130 12th Feb 2018 8:10pm
barrowg
Looking to get alloys instead of steels so I guess it’ll be 265/75 then
Post #686131 12th Feb 2018 8:11pm
jst
265.75R16 or 235.85R16 for alloys on your tdi would work well. both near as the same OD, one set just 30mm wider. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686208 12th Feb 2018 11:08pm
barrowg
perfect thanks alot great help
Post #686209 12th Feb 2018 11:13pm
iamthehough
ive got a similiar issue
Post #695979 24th Mar 2018 10:25pm
