Home > Puma (Tdci) > Central Lockkng.
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Central Lockkng.
The rear driver side door has stopped unlocking/locking when the button is pressed on my 110.
Before I take the door card off to investigate: are they a common thing to pack up and what is the best replacement? Is it a bad job?
Kevin
Post #683430 1st Feb 2018 3:53pm
camelman
Happens all the time! It's usually the actuator unit on the door.
You can get them for around 40quid, google 'defender central locking actuator'
Simple enough job to swap out.
Post #683433 1st Feb 2018 3:58pm
rustandoil
Mine stops working in the cold weather.... I have in the past taken the door card of and squirted a bit if WD40 around the mechanism and that's freed it off
Post #683436 1st Feb 2018 4:25pm
mk1collector
It will be the wires from the b post to the door inside the rubber sleeve that have broken. Very common and easy to fix with a bit of good quality wire and a soldering iron.
The wife's 64 Reg has already had one rear door do this Rolling Eyes Ray
My build thread
Post #683441 1st Feb 2018 4:51pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
As Mk1 says... wires inside the rubber conduit snap.
Post #683448 1st Feb 2018 5:28pm
diduan
Bulgaria
wire inside the plastic sleeve. be prepared, the other side is comming soon. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #683466 1st Feb 2018 6:54pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
99% chance of it being the wires. As diduan said, get ready for all the others to go. Try and get a roll of good quality cable(with a high number of conductors that can still be flexible in low temperatures) and do all the central locking wires and electric windows(if you have them) in all the doors. The cable size/quality JLR use is abyssmal(their procurement must just go out to buy the cheapest they can get hold of!!).
Each time you open and close the doors it creates wear on the cables which eventually causes the conductors to break. Its a pain in the ass to do, but if you do it with cable that should have been used in the first place you won't need to do it again.
Post #683585 2nd Feb 2018 10:01am
zsd-puma
Check the wires for continuity, if they're bad chop through them and replace with some new wire. If the wires are good it'll be the actuator in the door, but it's normally the wires.
Don't bother buying a new door harness from Land Rover, it's about £70 for a couple of wires with a rubber boot in the middle and a connector on either end, it'll fail just like the original in next to no time!
Don't try doing it in situ, take the door card off and remove the harness, there is a plug just inside the B pilar you can un plug it there. It'll take 5 min to remove the door card, or an extra 20 min of swearing trying to fix the wire in situ. You'll probably tear the foam water shedder behind the door card when you try to peal it off, so buy a new one, they're only about £8 from Land Rover.
Post #683631 2nd Feb 2018 3:27pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
My money is on the wires from the B pillar too. Had mine fail twice. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #683652 2nd Feb 2018 5:33pm
