Home > Td5 > Gear ratios - offset wheels
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Hey there
Just bought another TD5 finally after a long search, keen on a disco transfer box or Ashcroft ratio change anyone out there have any advice on the best way to go?
Also car has come with Dynamic steels wheels with a fair offset, the car seems to jump around a bit so I'm wondering if it's
the offset?
Any advice would be greatly appreciated Winter's here, thanks goodness!
Post #682810 30th Jan 2018 12:42am
bluebottle
Very much enjoying my Disco transfer box, contemplating chipping now...
Post #682811 30th Jan 2018 12:46am
Chamois
Nice, which Box did you go for? Winter's here, thanks goodness!
Post #682812 30th Jan 2018 2:58am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I fitted an Ashcroft ratio, a bit time consuming but fun in the process and it makes a world of difference when you've finished. It's like a new car.
Post #682822 30th Jan 2018 8:31am
isacs
I took my transfer box out, took it to a Land Rover transmission specialist and they changed the ratios to 1:211. Then I put it back in. If your box is low miles I’d go down that route, unless you can find the exact disco box you need for good money with comparable mileage
Post #682824 30th Jan 2018 8:36am
bluebottle
I’m not sure, it was done for me at an Indy. I suspect they just did a swap out for an Ashcroft...
Post #682849 30th Jan 2018 11:06am
miker
Got an ashcroft V8 5th gear in my box. It makes a noticeable difference on the motorway. Didn't want to go down the transfer box route as I do enough heavy towing that it would annoy me!
Post #682888 30th Jan 2018 1:52pm
Harry.O
I have the Ashcroft v8 5th gear as well, albeit combined with slightly taller tyres (285 75 r16) and a remap, very happy with it. At motorway speeds it doesn't drop the revs quite as much as a 1.2 Tbox but I don't spend a lot of time on them and wanted to retain flexibility for towing trailers. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #682897 30th Jan 2018 2:56pm
miker
I do a lot of motorway miles, I tend to slow down or wear headphones!
Post #682916 30th Jan 2018 4:13pm
CrazyK
United Kingdom 2002 Defender 90 Td5 CSW Cairns Blue
I changed mine to a disco 1.2 T/Box. very happy with it,
I don't do any towing with mine but on motorways and around down I feel the gearing is much better suited to my use.
70mph is very comfortable in terms of noise and vibration
Even well laden it still pulls fine on a standard engine
Kieron
Post #682931 30th Jan 2018 5:16pm
Jumping around?
Usually worn bushes and or dampers. QRZ 2e0vpf
Post #682932 30th Jan 2018 5:38pm
UtilityTruck
If they’re a very low offset (stick out a lot) your scrub radius could be excessive at the front, this can lead to wandering or nervous behaviour over bumps.
It’d be worth trying a standard set of wheels to see if the problems goes away. 2014 Keswick Utility 2.2
Post #682963 30th Jan 2018 7:41pm
