Home > In Car Electronics > Looking for ideas
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
Looking for ideas
I'm going to upgrade my radio to a double din. Looking around now at the Kenwood with apple play and DAB.
IS anyone else got one? How do you find it?
Looking to put an amp in and extra speakers
Post #682195 27th Jan 2018 9:26pm
I think Jomara on here has similar, but not in use yet I don't think. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #682202 27th Jan 2018 9:43pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Chris
I have ordered a Kenwood DMX7017DABS double din unit, loom, reversing camera and a Defender Upgrades dash with moving vents, just waiting for the kit to arrive and my car to come back from the dealers yet again to get it all installed.
Did a lot of reading and was nearly buying Pioneer but they have an issue with DAB tuner errors stemming from a non replaceable internal fuse popping. The Kenwood scored 5 stars on the Auto Express tests and the one I tried in a VW was remarkably simple to use and they don’t seem to any major problems at the moment.
Hopefully it will be up and running over next couple of weeks.
John 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #682212 27th Jan 2018 10:16pm
Keep us posted. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #682214 27th Jan 2018 10:18pm
chris d3
What do you look for when by an amp. I want to put more speakers in
Post #682444 28th Jan 2018 8:39pm
Match RMS wattage of Amp output to speaker RMS wattage. Or as close as you can.
So if your Amp produces 50wrms per chanel at 4 Ohm, that is one channel. You would need a single 4ohm 50wrms speaker.
(Or near).
That is an example, it also depends if wired in series or parallel as to your final impedance in Ohms and wattage.
Depends how many speakers you want but you'll likely require a 4channel Amp.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #682452 28th Jan 2018 8:48pm
chris d3
Basically at the moment I've got 2 10cm Hertz and Rainbow flat sub. I've also 2 16cm Hertz speackers that I'm going to put in the seat boxes. I'm starting at the front working back over.
I want to put the sub under the cubby box. Just want the best sound I can get out of it
Post #682519 29th Jan 2018 1:49am
