Home > Maintenance & Modifications > DE-badge the DE-fender or DE-value?
scottchad01
Wales 2008 Defender 90 Puma 2.4 SW Stornoway Grey
hi guys, been wanting to change the lettering on the bonnet from grey land rover to a gloss black DEFENDER badge. a good friend of mine owns a sticker garage doing car signage and shop signage so he will able to do it for me. however, he had some concerns the first being it will devalue the car? is this true? and also he had some concerns it would leave marks where the paint ha faded over time being a 58 reg, and possibly pull the paint off underneath.
does anyone have any experience doing so as to whether the paint will be faded with marks to show or even if the paint will chip?
also any opinions as to whether the car will devalue by this simple modification
thanks in advance
Post #682039 27th Jan 2018 1:05pm
Taking the Defender badge off will increase the value, in my opinion, it's one less job I'd do anyway.
I always thought the badges were a bit 'halfords'. It's obviously a Defender....no need for the label. QRZ 2e0vpf
Post #682042 27th Jan 2018 1:17pm
camelman
On a 10 year old car I doubt replacing a £10 badge is going to make much difference either way....
Post #682043 27th Jan 2018 1:19pm
mk1collector
Car shouldn't de value at all as you can just replace the original badges if necessary. As for fading paint, I doubt it on a 58 plate and a bit of polish would sort it out anyway. The paint lifting is possible but very unlikely if it's on its original paint. It sounds like your mate doesn't want the job to me. Ray
My build thread
Post #682044 27th Jan 2018 1:20pm
grafty99
+1 I really wouldn't worry about debadging. Easy to replace Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #682045 27th Jan 2018 1:29pm
camelman
just warm the old badge up with a hair dryer and it should lift off
Post #682046 27th Jan 2018 1:31pm
V8GPC
The beauty with owning a defender is you can do what ever you want to reflect your own personnel preference.
The early defenders hand the word "defender" on the grill; later "Land Rover" on the bonnet and eventually "Defender" and many different colours.
Easy to remove; wont de-value - if a future new owner didn't like the exact style - they'd easy see through the badges as its an easy fix.
To remove lettering a hair dryier helps; and to reomve any old glue or foam; WD40 to soak a little and with your thumb and a soft cloth eventually you get all traces removed without any paint damage. You shouldn't see any fading of the paint - if you do then just use some polish.
You'd beadle to do all this yourself without any special tools. Use masking tape to help you work out the correct position before you apply. Just make sure the new badges use the 3M backing foam adhesive stuff as this is the best.
Take your time - you'll be really satisfied once done Thumbs Up
Post #682052 27th Jan 2018 2:19pm
There will be paint fade there, I'd guarantee it but you'd hardly see really.
Removal use dental floss carefully to cut thought the adhesive and a toffe wheel to remove the rememants of the adhesive.
Possibly with some Isopropyl alcohol to soften the adhesive also.
I wouldn't recommend pulling them off at all. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #682058 27th Jan 2018 2:42pm
