Home > Puma (Tdci) > Mud Flap bracket rust
TOP5N
I have noticed that on my 2015 defender that the one front mud flap has a lot of rust showing (on the metal part that the mud flap attaches to) where the black coating has come off.... do you think they would change it under warranty, or am i just being too fussy on a utility truck...
Post #681123 23rd Jan 2018 7:39pm
mk1collector
We had ours replaced under warranty on the dcpu with no arguments. When these start rusting (which they will) we'll replace them with stainless ones. Ray
My build thread
Post #681128 23rd Jan 2018 8:02pm
Rashers
My 2014 ones are also rusting well. Haven't tried the main dealers yet. That will be my first port of call. I paid for a warranty in the purchase price, I will try and use it.
Which stainless ones are recommended? I was wondering about treating myself to a set of Gwyn Lewis ones?
Post #681131 23rd Jan 2018 8:08pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Mine rusted at 4 years. Didn't bother with the warranty, just bought stainless steel ones from YRM metal solutions and painted them satin black. Hardest bit was getting the original fixings out as they too had rusted solid!
Post #681146 23rd Jan 2018 8:57pm
TOP5N
Thanks for the replies. I will look up about the stainless steel ones.
Post #681158 23rd Jan 2018 9:25pm
Rashers
Just had a look at the YRM website. Nice stuff. Thanks for the heads up, Balvaig Thumbs Up
Post #681173 23rd Jan 2018 10:05pm
hornet
Re: Mud Flap bracket rust
Even more important is to replace the thread-rivets as soon as possible against new pieces in bigger dimension and stainless steel. If not done early, screw and rivet rust together with the result that the rivet-nut turns and you will not be able to loosen the bracket (in an easy way).
There are special tools you can use for new nut-rivets:
[/img]
Post #681337 24th Jan 2018 2:57pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
mine did the same, and when I went to replace them the rivnuts (as above) spun, so replacement was a bit of a nightmare.
I got some powedercoated ones fitted, hopefully they will last longer. Certainly look a lot better. Thumbs Up My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #681351 24th Jan 2018 3:51pm
zsd-puma
don't bother with the rivnuts. Just use stainless nuts and bolts. There is a hole in the outrigger big enough to get your hand in and drop the bolts through. Wink
Post #681396 24th Jan 2018 6:50pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I fitted this kit to the front as the Rivnuts were at one with the bolts and had to be cut off of the front outrigger.
It also has the benefit of stopping quite so much crud from getting in the door handle and onto the front outrigger.
https://gwynlewis4x4.co.uk/product/defende...9-rtc4685/ 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #681402 24th Jan 2018 7:14pm
zsd-puma
I did the Gwyn Lewis kits front and rear on my 110. Expensive but they'll pay for them selves in the long term by protecting the outrigger.
Post #681450 24th Jan 2018 9:02pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Another Thumbs Up for the Gwyn Lewis kit..
Post #681459 24th Jan 2018 9:31pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Yes the Gwynne Lewis kit is well worth it Thumbs Up
Post #681650 25th Jan 2018 8:18pm
