![]() | Home > Maintenance & Modifications > Tow electrics |
WD-40 which acts primarily as a dehumidifier works very well. ACF50 is more of an oily grease with anticorrosion capacities would be equally good. I spray WD-40 once a month or so into both trailer sockets and they stay as new for many years now already.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2272 ![]() ![]() ![]() |
Thanks Eric
![]() I did consider WD40 for the obvious reasons, but didn't think of using my ACF50 to be honest - I might give it a go considering I use it all over the truck anyway. I know both force moisture out so generally that'd be good preventative maintenance ![]() Cheers, Will |
The newer Land-Rover kits have the backs of the sockets filled with glue/plastic rather than just the rubber boot so they're completely waterproof from the rear.
The 13pin sockets (like all 13 pin sockets) also have stainless steel tubes, so they don't corrode like the brass 7 pin ones. |
