Home > Td5 > Cruise control not working after installing auto box
Page 3 of 4 <1234>
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
Thanks All
It does look like the clutch is 'pressed' then....
I'm at home today so will have a look for the wires and see about joining them.
Dave - if you can let me know where your lads tucked them that would be great.
Mike
Post #677626 11th Jan 2018 8:31am
msb
Ok, so I've had another look and rummage around the engine bay, and I just can't find any evidence of the clutch switch wiring.... Big Cry
The only loose plug is a 4 way, and doesn't have any black or black/white wires.
I can't find any 'new' tape or anywhere that looks freshly disturbed and might be where Ashcroft hid the wires.
So 3 options;
1 - If Dave can tell me what exactly his guys did with the wires, I can find them and join them.
2 - Can anyone tell me where their clutch switch wires come from, so I can have another go at finding mine and join them.
3 - Make the circuit at pin 35. When I had a go at this the other day it brough the engine light on, but I'm happy to have another go. It is ground at pin 35 I'm after, isn't it?
Thanks
Mike
Post #677670 11th Jan 2018 2:37pm
geobloke
Sure thing Mike, I am heading under the bonnet after work... Hold tight.
Post #677686 11th Jan 2018 4:25pm
ashtrans
Site Sponsor
Hi,
I checked today and I was wrong, closed circuit when off the pedal so yes the wires need connecting,
Did you get the photo Mike ?
Dave Dave
Post #677731 11th Jan 2018 7:46pm
msb
Hurrah! Some success Very Happy
With Dave's photo as a starting point (yep I did get it, thanks Dave)
And a bit of contortionism I eventually managed to feel a couple of inches of hearshrunk cable tucked in the back of the loom just after it comes through the bulkhead. Ashcroft had done a fantastic job of tidying up the wires!
Why is it there are so many jobs that you need fingers that are twice as long, and half as fat as mine, and that bend backwards??? Shocked
Anyway, eventually I managed to join the black and black/white wires and lo and behold my nanocom readings now match miker's! Clutch switch OFF.
Going for a spin we now see the differences in gearing between the ZF autobox and the R380...
In 3rd at over 2,000 rpm the cruise control wiill activate and hold a steady 42mph. So far so good.
I've not been out to the motorway yet, but couldn't find a speed/gear/rpm combination at 60 or less where the cruise control would activate in 4th....
With all your help my cruise control is now working again, so thank you very much for that, but I wonder if I could ask for a bit more help with getting it activate in 4th.
Does anyone know what combination of speed/rpm I need to be aiming for?
I'm running 235/85s.
Thanks
Mike
Post #677787 11th Jan 2018 10:46pm
geobloke
Well better late than never, albeit a tab useless now... Rolling Eyes Cable goes in to the main loom and through the bulkhead grommet behind the header tank.
Post #677851 12th Jan 2018 11:23am
msb
That's a good photo geobloke, thank you.
Ok, Dave beat you to it, but it's really helpful reminding me what was there before. If only I'd taken my own photos (or had a better memory) I wouldn't have had half of these problems Very Happy
Just need to understand the speed/rpm thing now and see if I get the cruise control to be any use to me on the motorway....
Post #677860 12th Jan 2018 11:42am
geobloke
What a Gent... Thumbs Up
I have so many photos of various vehicles in different states of dismantling or rebuilding, better than my memory after a month or so.
Can't remember if you have answered this already but which cruise system do you have? I take it the LR onboard one. Any tips for installation?
A mod I have been dying to do...
Post #677862 12th Jan 2018 11:47am
grafty99
As the gearing has changed you may now need a speedohealer between the Speedo and ECU so it thinks you're travelling slower than you actually are to bring it back into parameters that allow it to set Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #677902 12th Jan 2018 2:42pm
grafty99
Just checked the ratio calculator and it's only ~100rpm resuction, could be enough for the ECU to not allow cruise.
Do you have taller tyres? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #677904 12th Jan 2018 2:49pm
msb
Geobloke - basically i got a discovery switch off ebay, a couple of ecu pins and a bit of wire and followed this picture
There was a little more to it, but really not much. For the £20 and the hour so it cost me, it was great mod. As long as you have the standard transfer box (and gearbox) i would recommend it. Let me know if you need any more info or photos Thumbs Up
Grafty - 235/85s so nothing too big. I was wondering about a speedo healer, but wanted to try and understand it all first. I think i need to play around with the Ashcroft ratio tool http://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html
to see what's changed, but does anyone know what exactly in aiming for? What parameters/ range is the ecu looking for?
Thanks
Mike
Post #678015 12th Jan 2018 9:52pm
geobloke
Ahhhh so you did use the ECUs onboard cruise control. Excellent. Is on my list that is for sure.
Have found a kit by Landzeiger that is basically the same as what Terrafirma used to do before forcing folks to spend £400...
£20 for the Disco switch is great, can't seem to find it below £60 at the moment.
I will need a Speedo Healer as I have a Disco transfer box and 285/75/16 tyres. Speedo actually reads bob-on accurate to GPS now as it happens, but not according to the ECU Rolling Eyes
Post #678034 12th Jan 2018 10:54pm
msb
Ebay eBay Item No. 292406227528 £39.95 inc p&p Whistle
Post #678039 12th Jan 2018 11:12pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Well I used Nakatamenga td5 cruise control kit and it works fine..
You can check here
https://thegippo.wordpress.com/2018/01/23/...e-control/ Happy Travel
www.thegippo.wordpress.com
Post #688139 21st Feb 2018 11:12pm
msb
I finally found some time to sort this out.... and now have a fully functioning cruise control again Very Happy
After sorting the clutch switch etc, cruise control would work in 3rd only.
Finally getting round to fitting a speedo healer to pin B13 at the ECU and setting to -10% correction at the end of last week gave enough of a reduction to get the ECU to think I am travelling slower than I am and put the speed/revs back into the acceptable cruise control window, and voila! cruise control in 3rd, 4th, and most importantly 4th with Torque convertor engaged.
For completeness, the speedo healer is a healtech one from Craddocks.
It has to go to the ECU only, as fitting at the transfer box also makes the speedo read low Embarassed . The speed signal goes from the transfer box through the speedo before getting to the ECU.... white wire to speedo signal (speedo healer input) green wire (speedo healer output) to pin 13 on the black ECU plug, red to live, black to ground.
Thanks everyone for all your help with this.
Mike
Post #694787 19th Mar 2018 11:06pm
Page 3 of 4 <1234>
