![]() | Home > Maintenance & Modifications > Rear door hinge torque? |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
Hi all and a very happy New year I'm just about to put replacement doors on the red zepplin and having stripped down the hinges to repaint I'm just wondering if there's a torque setting for the rear hinge pins (can't dig anything on here or t'internet) set up is torq head set screw, hinge (upper), brass bush, hinge (lower) spring, nyloc nut thanks in advance
Simon WHAT COULD POSSIBLY GO WRONG My sky lantern petition http://chng.it/HJXmZC47 |
As the door will sit on the hinges just with under its' own weight, and they're designed to rotate, they don't need to be very tight at all. The 'tightness' is provided by the spring and the nylocs are mainly to stop the nuts falling off. Darren
Great thanks for that :thumbsup: WHAT COULD POSSIBLY GO WRONG
