Home > Technical > Rear lights went nuts - SOLVED
MK
Yes, for some reason indicators go off by pushing the brake pedal or in reverse Shocked Stop lights go off when using the indicator switch Shocked
Is this a bad earth or something related to the ECU (AS10 stuff)?
Shocked Shocked Shocked
Front lights are fine Rolling Eyes Puma 110" SW
Post #62897 9th Mar 2011 10:11am
Can top that Heated Rear Window on Rear Brake lights on (but not the High level one) quite fun when a corsa boy is a few inches off the rear bumper flick the HRW on and watch the panick Whistle
Post #62901 9th Mar 2011 10:19am
CarlW
Scotland 2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Yes, looks like a bad earth connection MY11 110 XS Station Wagon in Stornoway
Post #62949 9th Mar 2011 5:51pm
TC
That should be a factory option
Post #62996 9th Mar 2011 8:59pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
My radio went off today then came back on and the temp guage went off and i have a speed camera dectector wired to a spare switch next to the radio that only works when the radio is on Shocked and the heater fan works with the ignition on 1st position Thumbs Up
Post #63001 9th Mar 2011 9:16pm
Grockle
as already said,check the bulb connectors as these corrode badly and can cause shorting,clean the bulb holder as well then coat in vasaline(not grease as that can contain acids). Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63043 10th Mar 2011 5:09am
MK
It was the earth connection. Thumbs Up Puma 110" SW
Post #63075 10th Mar 2011 11:03am
