Home > Maintenance & Modifications > Webasto Thermotop V
grafty99
Webasto Thermotop V
I have been given Shocked a Webasto Thermotop V because my friend couldn't get it to work. I have done some research and found that it is the same as fitted to Discovery 3's. It is not controlled in the same way as the C (by applying 12v to [pin 2?]) But via W-bus signal.
Basically I'm looking for help from someone who is much cleverer than me to help me write some code to run it with an arduino or microcontroller.
I can handle the physical fitting (although any pointers are greatly accepted)
There is a video on YouTube of a guy who has an arduino running one but I want to simplify his code to work without all the LCD screen and buttons. If there is an off the shelf solution to this problem then I would much rather that!
The quicker I can get it running on the bench the quicker I can have pre heated loveliness and faster warm up times Mr. Green
Any help or pointers would be greatly appreciated Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #671081 15th Dec 2017 5:10pm
Martin
Site Admin
If you've not seen it, have a look at www.disco3.co.uk/fbh
I've got lots of wiring parts for the TTV: http://www.defender2.net/shop/webasto-wiring-parts-c15.html
Also look at the Webasto section of DISCO3 forum: https://www.disco3.co.uk/forum/webasto-fue...-vf96.html
There are a few off-the-shelf controllers available (Altox, BAS, etc)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #671082 15th Dec 2017 5:20pm
grafty99
Martin, many thanks for the info Thumbs Up
Is there any way I can get in touch with a disco3 member without signing up and posting to pm? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671088 15th Dec 2017 6:03pm
Martin
Site Admin
Sorry, no. Only takes a couple of mins to register, say hello and get to 3 posts Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #671096 15th Dec 2017 6:46pm
grafty99
Ok Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671098 15th Dec 2017 7:01pm
grafty99
After a fair bit of googling I've found this. Does it look up to the job?
https://rover.ebay.com/rover/0/0/0?mpre=ht...2776404068 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #671117 15th Dec 2017 8:50pm
