![]() | Home > Maintenance & Modifications > Chequer plate sill fitment - gasket, silicon or Dinitrol wax |
I dinitrolled Inbetween my cp and sill and as you say the back of the sill too
![]() My build thread http://www.defender2.net/forum/topic17615.html |
dickbowyer Member Since: 27 Nov 2015 Location: West Sussex Posts: 8 ![]() ![]() ![]() |
Which type of Dinitrol, seems to be many formulations. The high performance wax?
Last time I fitted a set, I stuck some self-adhesive closed cell foam, 2-3mm thick, to the back of the CP, which worked well. There shouldn't be a corrosion issue between the two panels as they're both aluminium, but it stopped crud building up between them.
I also secured them with 6mm nylon nuts and bolts. There's little to no load on them, even if you bash the cills, and they avoided rusted bolts. It could also be done with stainless bolts and nylon washers to separate the metals if you wanted to. I've got quite a collection of different sized nylon washers now, as they're really handy for this sort of thing. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 534 ![]() |
I am going through this same scenario with the bonnet on my 110. But I am going to stick it on with TigerSeal and also rivet it. No corrosion, not coming off and therefore won't create any issues
