Home > Maintenance & Modifications > Where can I find-
Blindpugh
United Kingdom 2000 Defender 130 Td5 HCPU Cairns Blue
Where can I find-
Hello all I wish to get rid of the middle box on the exhaust of my 2000 TD5 130, I'm guessing it's the same as a 110 middle pipe so who makes /supplies a straight through pipe.
As I have already done the EGR and have a K&N filter.
Many thanks for any help. He who dies with the most toys wins.
Post #62630 7th Mar 2011 2:52pm
Naks
Re: Where can I find-
Blindpugh wrote:
Hello all I wish to get rid of the middle box on the exhaust of my 2000 TD5 130, I'm guessing it's the same as a 110 middle pipe so who makes /supplies a straight through pipe. As I have already done the EGR and have a K&N filter.
Any decent exhaust shop should be able to do this, simply get them to weld a piece of mild steel in the place of the middle box, should only cost you a few bucks Thumbs Up --
Post #62632 7th Mar 2011 3:02pm
fekete
Try Alive they are site sponsors
Here
http://www.td5alive.com/exhausts.php NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #62640 7th Mar 2011 3:32pm
K9F
Not a TD5 but the aftermarket exhaust system I got fitted binned the cat, replaced the offset centrebox with a straight through box, and binned the rear box instead! Not sure of the TD5 set up but it does amaze me the different configurations you can get away with! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #62643 7th Mar 2011 4:01pm
