Home > Maintenance & Modifications > 35's on :)
Page 1 of 3 123>
camelman
35's on :)
35 inch KO2s on and Corbeaus fitted Smile
Post #668232 1st Dec 2017 3:07pm
geobloke
Damn those are meaty! Thumbs Up Thumbs Up
What are the seats like compared to the standard Puma ones?
Post #668236 1st Dec 2017 3:36pm
camelman
The bases are firmer and the uppers are definitely more 'figure hugging' !
I'll be putting the original XS heated seats up for sale on here in a day or so.
Post #668237 1st Dec 2017 3:42pm
JOW240725
Obviously wider arches, lift too? Looks great, how do they ride? James
Instagram @suffolk_rovers
Post #668262 1st Dec 2017 5:47pm
camelman
They're the Terrafirma +50mm arches which I've had sprayed up to match the truck.
Glyn Lewis 50mm suspension spacers front and rear so still standard springs and shocks.
The wheels are 15x10 ET-33 so the track is approx. 120mm wider than standard
They ride well, had 285s on previous so not a massive amount of difference.
Going to fit the front cranked arms next week and then should be done Smile
Post #668264 1st Dec 2017 5:57pm
geobloke
Standard shocks and +50mm spacers? Surely that does not leave much travel in the shock?! Am I wrong!?
Post #668268 1st Dec 2017 6:02pm
camelman
The rears have had the shock mounts lowered with a Glyn Lewis Shock Drop plate so maintain their original travel.
I had an in depth discussion with Glyn around the front ones and he reckons there's enough travel in the standard front shocks not to cause an issue unless you're going rock crawling Smile . I'll run them for a while and see how they get on...
Post #668278 1st Dec 2017 6:42pm
JOW240725
That's good to hear, thank you. James
Post #668303 1st Dec 2017 8:46pm
keith
Nice looking truck Camel , but I’d be kicking off those silly wee lamps on the roof and putting on full size light bar
Keith
Post #668309 1st Dec 2017 9:01pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
savage, i am wondering whether to fit 35's. is there much rubbing with the body work
Post #668321 1st Dec 2017 9:42pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Wheel tyre combo looks great.
Post #668323 1st Dec 2017 9:51pm
camelman
You need the 50mm lift and the wider arches to avoid rubbing, appears to be sufficient clearance without having to modify the bodywork further though
Post #668327 1st Dec 2017 10:08pm
Retroanaconda
You’ll be conquering the speed bumps at Tesco with ease now! Thumbs Up
Post #668388 2nd Dec 2017 10:35am
Spectre
Why not just fit new 2" lift springs and shocks?
Post #668813 4th Dec 2017 1:58am
camelman
There's nothing wrong with the original springs and shocks and the lift kit is only £100 ish.
Post #668828 4th Dec 2017 9:26am
Page 1 of 3 123>
