![]() | Home > Technical > EGR cleaning |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
According to the workshop manual, you can remove the EGR and generally give it a good cleaning with a wire brush and a bit of sand blasting. Actually very easy to do. This is of course only relevant to the 2.25 diesel 88/109 sold in Australia
![]() Imagine if you followed those instructions for the Puma EGR and then went to your dealer to claim under the warranty! ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
I cleaned my EGR valve in a tub of hot soapy water, left to soak over night.
Then used a small wire brush to get baked on crud off. I then left it to soak in WD40 for a few hours, looked mint afterwards, then i removed it! |
