Home > Td5 > Td5 vacume pump oil drain outlet pipe
Ogboniman
United Kingdom 2003 Defender 90 Td5 SW Nato Green
Hi the oil drain outlet is facing the wrong angle on a new aulternator with vac pump attached.
Any one how to remove the oil drain outlet pipe on the pump, this is a td5 engine
Post #666232 22nd Nov 2017 4:02pm
If my memory serves me, the oil outlet pipe is fixed on assembly and you cannot remove it or rotate it.
My immediate suggestion is to return the alternator and ask the supplier to replace it with one that fits!
Post #666236 22nd Nov 2017 5:02pm
Ogboniman
Reply
Hi Blackwolf,
Thanks for that I reckon your right, I’ll see what I can do but I think I’ve had it to long to return,
Cheers.
Post #666269 22nd Nov 2017 6:27pm
