![]() | Home > Maintenance & Modifications > prop-shaft upgrade advice needed |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
if its doesn't have dislocating suspension i would stick with std props. Cheers
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
I run the Gwyn Lewis props front and rear. Competition or not its nice to know you have something with fully greaseable shaft, UJs etc and is slightly oversized and more heavy duty. Fully replaceable components so buy them once and you can repair them forever (if needed - grease regularly and they'll last as long as you need them to)
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
Unless youre doing anything extreme or running high power id stick to standard and replace with the GKN UJs
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
+1 for Gwyn Lewis, hard to beat.
