Home > Puma (Tdci) > Door checker bracket re-install |
Can you get to the back? If so, then nuts and bolts. If not then a suitably sized rivnut. Darren
14th Nov 2017 3:24pm |
Simon.pl Member Since: 15 Mar 2016 Location: Warsaw Posts: 98 |
No, of course there is no way to get there from the other side. Otherwise it would be obvious.
Been thinking of the proper rivnet as well. Just thought there were other "repair kits" available. |
14th Nov 2017 3:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
With a bit of Googling you should be able to find breakstem fasteners up to at least 10 mm dia. Finding somewhere that'll sell 2, and ones that can be set without special tooling might be harder though.
Failing breakstem, then go for Rivnuts. |
14th Nov 2017 4:54pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
As this part only locates the door stay and is not under any great load, hence why it is only riveted in place why not drill out the rivet and sikaflex adhesive it in place For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
14th Nov 2017 5:59pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
Can't you weld it instead? I reckon it would extra strong if welded... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
14th Nov 2017 6:30pm |
Yes - I could weld it in, but seeing it damaged (to some point) I would like it to be demountable for future potential repairs.
Gilarion - I've seen few times the door "fly away" with a heavy wind - I think there are quite significant forces applied in such circumstances. Will use 9mm stainless steel rivnuts for M6 screw. Cheers everyone |
14th Nov 2017 8:07pm |
Door checker bracket. the bar that attaches to it is called the check strap or door checker. The part number for the bracket is LR020252, it's only about 20 from Land Rover. Seeing as yours looks to be bent you may as well fit a new one i think? Annoyingly Land Rover don't seem to list the rivets on their catalogue. |
14th Nov 2017 9:03pm |
Thank you zed-puma - new word every day
Interesting to know that this check arm can be bought as a spare part. Contacted LandPartsSystem here in Poland yesterday (they sell Land Rover parts) and the guy told me this part was not available as a spare Well - repaired mine and will use rivnuts as fixing plus some strong glue underneath. Click image to enlarge |
14th Nov 2017 11:56pm |
