Home > Technical > Webasto fuel pick-up
Page 2 of 2 <12
TJH1985
I ran mine into the fuel pump #1 on the diagram. Single line from the tank to the FBH filter passed through a rubber outer hose to seal it onto the pump and line. I have overfilled the tank and it doesn't leak and is nice and simple. Was around 30 minutes to fit, lowered the tank a couple of inch providing just enough room to work.
Post #748263 31st Dec 2018 3:56pm
jst
Does anyone know if they inline filler pipe pickup works on a HiCapacity where the fuel line angles are a bit different?
Plus does anyone know the ID of a 110 fuel pipe? i see 90 dims are given ,assume 110 is 60mm? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880021 21st Jan 2021 10:27pm
Matt110
Have you got a photo of what the pipe looks like and I'll have a look. Not got mine to hand any more as have fitted it but could look to see if it would fit or not. As long as you have a horizontal piece of pipe running straight into the tank with no further bends you should be fine.wpuld need minimum of about 100mm AFTER the plastic tank tube extension, before the next bend.
Post #880042 22nd Jan 2021 12:21am
jst
cheers i will take a look. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880183 22nd Jan 2021 7:27pm
jst
Webasto evo ordered and am going to use this pickup on the 130. Tank one already in use for Airtop.
So 60mm? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #893953 25th Mar 2021 9:03pm
jst
ok, pipe on 110/130 is 60mm ID.
question is anyone fitted one of these to a pickup/hicap back - is there a long enough straight to fit it in? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #894089 26th Mar 2021 11:47am
Matt110
Still happy to go measure mine if it helps, i'm going out to it later anyway.
We could measure the minimum distance on mine and you could translate that to your 130 to see.
Post #894091 26th Mar 2021 11:50am
Page 2 of 2 <12
