![]() | Home > Puma (Tdci) > I've inadvertantly coverted my 110usw into a 3 seater |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346 ![]() ![]() ![]() |
I've dropped 2 of the back seats (simply folded down the backs) and now they won't go back up cos the seat belt has jammed on the middle seat preventing it from folding back up ......any thoughts please?
How irritating.
How about undoing the upper mount bolt? should be just a plastic cap over the head of the bolt. 17/19mm IIRC. Good luck |
thanks for the note. unfortunately this is the middle seat / seat belt that's causing the problem and as such I don't think what you've suggested is an option.
![]() blo*dy annoying. supposed to be giving someone a lift later too. |
Ok, same advice then but the lower seat belt mount.
![]() Out of interest what age Defender is it? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
I struggle with our middle seats sometimes although sounds a different issue. I generally find walking away and trying again another day works
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
thanks guys - sorted.
IRB & co removed the seat base and removed the seat belt anchor point which released the seatbelt and hence got the seat back up. it would appear that the little plastic thing on the seatbelt which I can only assume is to prevent the belt retracting too far got stuck somehow / somewhere around where it retracts into the seat? like I say sorted now. I think the answer is to introduce some slack before dropping the seat backs ![]() what a fiddle.....just like the rest of the car ![]() |
