![]() | Home > Maintenance & Modifications > New batteries |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
The Optima red top(50 Ah) is considered to be a starter battery and the yellow battery (55 Ah) is a combined starter/leisure battery with CCA of 840 amps.
Whereas the Optimas used to be considered the best battery available that claim is probably now with Odyssey batteries. The Optima and the Odyssey 1500 (68 Ah) with CCA of 880 amps are very similar size however the Odyssey is considerably heavier around 3-5 kg heavier. Why? More lead plates really as you can fit more in a rectangular volume then the 6 spiral cans of the Optima which has dead space due to cylinder packing. Possible depth of discharge DOD on Odyssey is 80% whilst possible to start engine at 70% DOD. Can not readily find DOD on Optimas. I used to run on twin Yellow tops, but after they died have fitted twin Odyssey 1700 in red 110, twin Odyssey 1500 in black 110 and a Odyssey 1500 in D2 Have the Genysis management system in red 110 and the IBS in black 110. I prefer the IBS system as the Genysis system seems not to like it if one battery goes very low, (goes through continuous start sequence loop). The IBS system also gives an audible warning of a low battery status whereas the Genysis system only gives a visual one. Have not used the National Luna system so can not comment on that system. I would recommend twin Odyssey 1500 and an IBS. Yes you can get twin 1700's in a Defender battery box but it is a tight squeeze HTH Brendan |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Thanks
