Home > Maintenance & Modifications > Remove rear fog/reverse light plinth
stephan123
Hi,
Has anyone removed the factory-fitted rear fog or reverse light plinth? I need to swap it with a different plinth as the rear lights i have bought do not fit. Seems like the bolt needs to be unscrewed from the rear but cant figure out how to access.
Many thanks
Stephan
Post #660592 30th Oct 2017 4:34pm
You'll need to remove the plastic shields that conceal the backs of the lights from inside the rear wheel arches. You'll then be able to see the nuts securing the plinths. Darren
Post #660594 30th Oct 2017 4:39pm
stephan123
Many thanks!
Post #660955 31st Oct 2017 6:56pm
