Home > Maintenance & Modifications > LED Rear Lights
CEEGEE
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
LED Rear Lights
I am planning to replace the rear lights / stop lights on my TD5 for LED so that they are brighter / more effective.
I want them to be a direct replacement and the same size.
Does anyone have suggestions on the best place to get them from ??
Are they easy to wire up or is there some 'fiddling' to do ??
Thanks
Post #658919 22nd Oct 2017 2:47pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I assume you have the "normal size" of 73mm diameter rather than NAS style about 95mm from memory.
The two main manufacturers of such items are Wipac and RDX.
I can't vouch for the RDX ones as I have the Wipac version fitted to my defender and they have been superb for the last 4 years.
They are plug and play with the correct connectors and even come with new screws.
Your favourite Land Rover parts place is probably as good a bet as any for picking them up. I did think that Brendan sold them but cannot see them on his website. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #658923 22nd Oct 2017 3:04pm
Screbble
I've had RDX fitted for a few years and they've been spot on. The bay of e lists most of the RDX offerings.
They look like the originals even close up - I wanted to retain the factory look.
No fiddling or modifications required - plug and play.
they make a significant difference in terms of others being able to see you, however we are benchmarking and comparing to the originals which are poor to say the least.
Wipac have good reviews also as Phil has testified.
Hope this helps Thumbs Up
Post #658929 22nd Oct 2017 3:29pm
CEEGEE
Thanks chaps, very helpful Thumbs Up
The Land Rover ones are terrible - can't believe I've not done it before now Neutral
Post #658934 22nd Oct 2017 3:38pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Had the RDX ones fitted for a couple of years. Look very similar to the originals. They were very easy to fit with same connections as the originals.
You only mention stop and tail lights. They are straight swop. If you fit the LED indicators you need to change the relay to the adjustable one that RDX sell. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #658937 22nd Oct 2017 3:44pm
CEEGEE
Yes, just planning to do the tail / stop lights for better visibility with winter on the way Thumbs Up
Fairly happy that the indicators do the job okay Thumbs Up
Post #658940 22nd Oct 2017 3:55pm
Screbble
You should be able to get the stop/tail LED's for less than £20 if I recall.
The distance you can be seen from is significantly increased which as you say will make a difference as the nights darker nights draw in.
Hope you get them and have no problems with the fitting as its effectively a direct swap Thumbs Up
Post #658977 22nd Oct 2017 6:46pm
cyk1
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Has anyone fitted the black pack LED lights from Nakatanenga? Pics would be great. Are they really plug and play? Really do not want to start drilling new holes!
Post #660775 30th Oct 2017 11:55pm
AJC
Wipac full kit on mine with no issues
Post #660813 31st Oct 2017 7:49am
discomog
Likewise. Wipac LEDs stop tail and rear indicators. Plug and play. Had them fitted for over two years and no problems. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #660840 31st Oct 2017 9:25am
Martin
Site Admin
You can upgrade pretty easily to the 95mm NAS/SVX type LEDs too if you want more lamp surface area  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #660841 31st Oct 2017 9:33am
There's at least one person that's fitted the Nakatanenga lights. See here:
http://www.defender2.net/forum/post654588.html#654588 Darren
Post #660842 31st Oct 2017 9:34am
Martin
Site Admin
95mm OEM lamps:
No bodywork drilling, totally reversible.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #660843 31st Oct 2017 9:37am
cyk1
Thanks guys. I think the black leds will look good against my Stornaway 90!
Post #661014 31st Oct 2017 9:50pm
