Home > Technical > 12v Battery Query.
tony.g
12v Battery Query.
Hi,
Have a perfectly good 12v battery which I want to keep as a spare. Is it best to keep it always fully charged (and how often should it be charged?), or is it best to occasionally run it down and then re-charge?
Thanks.
Post #658410 19th Oct 2017 6:23pm
zsd-puma
A decent maintenance charger is best for them. There are various smart chargers available, Lidl often do a cheap one. But there are also solar chargers which are quite good.
Failing that giving it a gentle over night charge with a normal battery charger once a month should keep it reasonably healthy.
They don't normally fare well if you just leave them to run flat and store them flat, that normally kills them pretty quickly.
Post #658414 19th Oct 2017 6:37pm
pannawonica
Australia
Batteries tend to discharge more either side of @24 degC, not liking extremes of temperatures!👍
Post #658489 20th Oct 2017 2:30am
miker
Assuming a lead acid, leave it on a ctek permanently, it will take care of the rest!
Equally, I have had batteries sat spare and just charged them every few months, and not noticed any real deterioration
Post #658678 21st Oct 2017 1:06am
tony.g
Thanks all for responses - will take onboard.
Post #658682 21st Oct 2017 6:25am
