Home > Maintenance & Modifications > Fixed mounting of ARB twin compressor, where?
Cupboard
Has anyone mounted one of the ARB twin compressors inside their Defender, if so where have you put it?
I think I'd like to fit one in to my engine bay but not sure where it would fit! I might be able to fit it under the driver's seat but that's currently full of recovery kit.
Post #656711 12th Oct 2017 7:46am
Under the driver's seat seems to be the usual place. The twin compressor is quite a big lump.
You'll regret keeping your recovery gear under the seat the day you get stuck somewhere you can't open the driver's door!
Post #656719 12th Oct 2017 8:55am
Cupboard
I have been in that situation!
Thing is it's got to go somewhere. The recovery kit would be easy to move in to the back. Easier to get at there.
Post #656728 12th Oct 2017 9:46am
sako243
What about tucked up behind the rear passenger wheel? It's a pretty big space there on a 110 - I've fitted an air tank of a P38 there for my on-board air setup (uses an air-con pump).
Not ideal in terms of mud and water but I'm sure you could shield / box it in well. If you're not adverse to cutting into the seat-boxes you could always make it accessible from inside the boot via a hatch. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #656773 12th Oct 2017 1:54pm
Mo Murphy
Mine is mounted behind the passenger seat in my 90.
50 Shades of Pennine Grey
Post #656807 12th Oct 2017 4:10pm
