Home > Off Topic > Workshop tools explained.
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Quick guide of essential tools and their use for all DIY freaks:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest
and flings your soda across the room, splattering it against that
freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprints
and hard-earned guitar callouses from fingers in about the time it
takes you to say, 'Yeouw....'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age, or for perforating something behind
and beyond the original intended target object.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation
of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs. Caution: Avoid using for
manicures.
HACKSAW: One of a family of cutting tools built for frustration
enhancement. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile
upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
known drill bit that snaps neatly off in bolt holes thereby ending any
possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most
shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called
a drop light, it is a good source of vitamin D, 'the sunshine
vitamin,' which is not otherwise found under cars at night. Health
benefits aside, its main purpose is to consume 40- watt light bulbs at
about the same rate that 105mm howitzer shells might be used during,
say, the first few hours of the Battle of the Bulge. More often dark
than light, its name is somewhat misleading. The accessory socket
within the base, has been permanently rendered useless, unless
requiring a source of 117vac power to shock the mechanic
senseless.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
lids, opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact gun that grips rusty
bolts which were last over tightened 40 years ago by someone at VW,
and instantly rounds
off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent to the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well on contents such as seats, vinyl records, liquids in plastic
bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while in
use. It is also useful for removing large chunks of human flesh from
the user's hands.
DAMMIT TOOL: (I have lot's of these) Any handy tool that you grab and
throw across the garage while yelling 'DAMMIT' at the top of your
lungs. It is also, most often, the next tool that you will need after
a really big hammer 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #656144 9th Oct 2017 7:40pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Rolling with laughter Thumbs Up
Post #656146 9th Oct 2017 7:50pm
geobloke
Rolling with laughter Rolling with laughter Thumbs Up Thumbs Up
Love it...
Post #656147 9th Oct 2017 7:54pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Sounds about right Rolling with laughter
Post #656148 9th Oct 2017 7:57pm
Coatesyyy
Dammit tool Mr. Green Rolling with laughter
Post #656152 9th Oct 2017 8:04pm
lohr500
Love it !!!
Don't forget
Conical Drill : A handy device for making that hole just a bit bigger than you intended/needed.
Grease Gun : Designed to give long lasting protection to the metal shelving on which it sits between uses through it's magical ability to turn grease into oil.
Air Ratchet : A wonderful piece of kit for spinning off nuts in hard to reach places until the nut being removed causes the ratchet to be jammed up tight against an opposing surface, rendering the reversing switch inaccessible.
Cheap Air tools : Time saving tools that actually make the job ten times longer than using the equivalent hand tool because every time they are called upon they need a full strip down/rebuild to coax them back into life. Ditto. Mig Welders.
Post #656160 9th Oct 2017 8:34pm
Rashers
Thank you so much. That has lightened my day Rolling with laughter
Post #656163 9th Oct 2017 8:40pm
ian series 1
Thumbs Up Mr. Green 80" 80" 86" 88" 90"
Post #656165 9th Oct 2017 8:47pm
Laughing ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #656167 9th Oct 2017 8:49pm
mini Anaconda
Rolling with laughter Bow down BORG - Bucks & Oxon 4x4 Response Group
Post #656168 9th Oct 2017 8:51pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Some of those sound familiar! Laughing Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #656176 9th Oct 2017 9:06pm
L110CDL
Nice one Rolling with laughter Clayton.
Keeper.
Post #656216 9th Oct 2017 10:16pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
2T ENGINE LIFT.
That increadably good tool at testing the tensil strength of anything you forgot to undo. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #656223 9th Oct 2017 10:31pm
bluebottle
Excellent! Thumbs Up
Post #656281 10th Oct 2017 10:40am
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
1st tool that comes outta my tool box at the mo is a BATTERY GRINDER Banging Head πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #656314 10th Oct 2017 1:08pm
