Home > Puma (Tdci) > Front washerjet replacement on a Puma
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all,
I just noticed today that my front washer jet was missing Shocked
It should definitely be a warranty job but TBH I don't really feel like going to the dealer and spend a day just for that if I can avoid it...
Although the spare is just a few quids, I wonder how hard of a job it is to replace it on a Puma? I've seen a few threads on other forums but these were for the TD5 and alike, I am not sure how to proceed on a Puma, does it require taking the dashboard off??
I think the reference for the spare is AMR3025 (for example here at Paddock), am I correct? Does that part fit on a Puma?
Also, do I really have to replace the whole part or could I just put the end cap that''s missing here?
Any hint welcome!
Cheers!
Post #61298 27th Feb 2011 4:29pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
I like this thread, even if my idea is to install a second jet so to have a more efficient cleaning even if i drive on a motorway Smile
I had the dual jet on my Td5 but i didn't do the job myself. I have tried on the puma to open the dashboard and seems a bit of a nightmare. I know that AndrewS has done an amazing job so he might be the best one to tell us how difficult it is to get aggess to the rear of the dashboard and replace/add a washer jet. Bow down
Post #61299 27th Feb 2011 4:44pm
mse
Opening the puma dash isnt that problematic.
But to change the front jet you should find enough give when you pull the old on off...to push the new on...just dont let it go! Mike
Post #61301 27th Feb 2011 4:52pm
o4dn
Thanks Mike Thumbs Up
Is it safe to pull? On that picture, there's a nut... And assuming this is the correct part, how to tighten it back in place?
Cheers!
Post #61305 27th Feb 2011 5:09pm
mse
you may want to check then...the front i dont remember having one - the rear did though Mike
Post #61314 27th Feb 2011 7:03pm
Ninetenths
2007 Defender 110 Puma 2.4 XS CSW Java Black
The end piece you are missing just pushes on, 2 second job. If you dont use enough antifreeze in your windscreen wash the ice can force this piece off. Pimped black '07 Puma
Equally Pimped Black Pick up Truck
Rollin deep
Post #61327 27th Feb 2011 8:17pm
o4dn
Thanks! Thumbs Up
Post #61383 28th Feb 2011 9:00am
mse
that will be why! Mike
Post #61446 28th Feb 2011 4:41pm
SteveNorman
You may find a problem, you used to be able to spearate the new one & push the missing bit on your exisiting stub, but the new ones come superglued on, & usually mean unbolting from the rear.
Order one up & see if you can separate it, you can see the traces of glue if they are glued on. Crying or Very sad
Steve
Post #61577 1st Mar 2011 8:57am
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Are all the new parts superglued on? Or can the br brought separately?
Post #586026 18th Dec 2016 11:21am
SteveNorman
I've found the genuine Landrover, Britpart and Allmakes ones are all glued on. No separate parts
Post #586070 18th Dec 2016 2:48pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've just replaced mine today.
Not wanting to rip the dash out over Christmas, I thought I would have ago at "doctoring" a cheap washer jet.
I brought a cheap one off EBay, cut the plastic pipe where it goes into the jet body,
Then using a 9.5mm drill bit, you can then drill out the inner pipe which is bonded into the main body.
A small amount of Araldite applied around the old stub that protrudes out of the bulkhead, saw my washer jet working again.
A simple fix that takes around 10 mins. Thumbs Up
Picture shows the jet cut and drilled ready to be fitted.
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #586377 19th Dec 2016 6:32pm
RED-DOT
The part you have lost CAN be bought seperately saving you from splitting a complete part. They stay on longer than a stretched one, i should know i'm on my fourth one.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #586392 19th Dec 2016 7:46pm
ian series 1
Where did you get it?
I couldn't find one, although I didn't spend that long looking... 80" 80" 86" 88" 90"
Post #586403 19th Dec 2016 8:09pm
RED-DOT
I bought mine from Strathearn Engineering near Aucterarder. They keep them in stock. Genuine part. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #586405 19th Dec 2016 8:15pm
