Home > Maintenance & Modifications > Rust prevention on rear tow step
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Hello, I have just bought a new rear full width step with tow bar integrated and thought that I should treat for rust prevention before fitting. My plan was to put ACF50 under the ?rubber tread plate, and use dinitrol cavity wax for inside the tubes. After this, would it be sensible to fill the large end holes and the other tiny holes around some of the tubes (currently have some black mastic on them). Or would this actually cause problems with internal condensation and better to leave open as drain holes etc. Any thoughts? thanks, Jerry
Post #655073 5th Oct 2017 10:37am
MartinK
If you have a towbar...
I too mine off and put a fixed, galvanised simple step on:
Mine's a bit battered now...
bout £15...available in lots of places:
https://www.amazon.co.uk/towbar-step/s?ie=...bar%20step
or
http://www.ebay.co.uk/itm/Towbar-Rear-Step...SwZJBX-7Jw
Mine will never rust now as it's stored in a dry garage Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #655078 5th Oct 2017 10:44am
Fat Cog
In ACF50 we trust... Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #655196 5th Oct 2017 9:04pm
LR90XS2011
your plan sounds fine to me but leave the holes open, liberally spray/wipe with ACF50 every few months iand it will last a long time DEFENDER 90 TDCI XS,
Post #655198 5th Oct 2017 9:07pm
Paint the faces that mate with the cross member with Waxoil or Dinitrol before assembly to keep the moisture out of the joints. Darren
Post #655221 5th Oct 2017 10:18pm
Jerry
thanks for the advice all. very helpful.
Post #655241 5th Oct 2017 11:26pm
