Home > Maintenance & Modifications > Spacers - are there any benefits from having them
wyvern
Just found out that my latest 110 has got wheel spacers fitted to it and was wondering what, if any, benefits they have to normal wheel mounting.
I agree that they look nice with a slight wider stance but not sure if that is the only benefit. Theoretically I can see that a slightly wider stance may improve stability at speed, but was wondering what else would be improved.
I was also looking at the negatives, such as extra wheel nuts to be checked and possible issues of stress on the axles etc....
any thoughts ?? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #652284 23rd Sep 2017 3:23pm
Not a fan, they often come with far more issues than are worth.
Somone here recently had a wheel come off due to one! ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #652286 23rd Sep 2017 3:42pm
bankz5152
As long as they are hubcentric, quality and torqued up properly youll have no issues.
I ran them on my 90 for 5 years with no issues.
Post #652288 23rd Sep 2017 3:51pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Quite a few fails on youtube.
Post #652298 23rd Sep 2017 4:28pm
grafty99
I ran them for a couple of years until I got offset wheels.
Advantages are:
Increased lock (reduced turning circle),
Wider track (cornering stability),
And in my opinion better looking.
I had no issues with mine at all and probably did circa 40,000 miles inc towing etc.
Disadvantages are:
Increased dirt from tyres up the sides of the vehicle,
20 more nuts to be torqued,
Increased unsprung weight. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #652301 23rd Sep 2017 4:40pm
SonicFields
Another, less obvious disadvantage relates to insurance problems, as their fitting must be declared to your insurer and in turn your insurer may require that any modifications made are approved by the manufacturer of the vehicle.
Failure to declare such modifications such as wheel spacers to your insurer, could make your insurance void, something you would not wish for in the case of an accident.
I believe that certain countries/ states ban the use of wheel spacers.
Post #652318 23rd Sep 2017 6:52pm
benniferj
I'd always go for replacing wheels with something with your required offset. Less bits to go wrong and nice and simple to bolt up. Good offset modulars don't cost much. Many alloys have different offset versions...
Post #652327 23rd Sep 2017 7:53pm
JOW240725
I ran spacers for a year primarily to improve turning circle, which makes a vast improvement. Declared and made no difference to insurance premium. No issues at all with them. James
Instagram @suffolk_rovers
Post #652341 23rd Sep 2017 9:01pm
Pickles
Spacers are illegal in Aussie.
Pickles.
Post #652359 23rd Sep 2017 10:15pm
Bluest
If I recall correctly from when I used to read Racecar Engineering, increasing the track width reduces the effective roll stiffness. The contact patch is further from the roll centre giving the wheel more leverage over the spring and arb. So there should actually be small reduction in stability with spacers fitted. I'd imagine in truth the effect is pretty small. 2007 110 TDCi Station Wagon XS
Post #652364 23rd Sep 2017 10:45pm
This is one of those subjects that comes up on a regular basis and the outcome is always the same. Some will claim that they're a bad idea for various reasons, usually including increased wheel bearing load or something about the steering geometry. There will also likely be a post about how they read/heard/had a mate that claimed they knew somebody who's wheel fell off but can never quite find the original source of the story. Others will chip in that they've run them for years without any problems.
The reality is almost certainly somewhere between the two: yes, there will be marginal changes to forces on bearings and steering geometry but it's only likely to be significant or noticeable on a smaller 'ordinary' car. On a Defender, the former is well within the capabilities of the bearings (and no different from wheels with a greater offset), and the latter is undetectable give the relatively crude steering and suspension set up.
As for wheels falling off, the only reason why this would be a problem on a Defender with bolt-on spacers is if they haven't been installed correctly. That may be different if using bolt-through spacers, but they're really only suitable for road cars anyway. Darren
Post #652392 24th Sep 2017 9:12am
