Home > Maintenance & Modifications > TD5 Wiper motor removal
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Can someone explain what I need to do to disconnect the wiper motor from the rod that goes into it? I looked at the nut, and assumed it was undo nut and pull off...but it seems not, or at least, I haven't managed it yet. Is there more to it?
 1998 110 300Tdi White Hard Top
Post #647415 31st Aug 2017 3:55pm
You need to remove the motor from its' mount and then remove a plate from the rear that secures the end of the drive tube.
This is a tdi motor but the principal is the same:
 Darren
Post #647422 31st Aug 2017 4:14pm
Interlet
Ahh I see. Cheers Anorak. I'd removed it from the mount, but was perplexed by the next stage! Thanks! 1998 110 300Tdi White Hard Top
Post #647423 31st Aug 2017 4:17pm
Or, if you remove the wiper arms themselves, you can pull the inner cable right out of the "tube" that runs between the wiperboxes (remove the wiper arms because the shafts will spin around a lot when you pull said cable out)
Be careful though, it's a long greasy messy thing... use rubber gloves and maybe another pair of hands to grab the end. good time to re-grease it when you reassemble it.
Post #647560 1st Sep 2017 7:11am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #647574 1st Sep 2017 8:28am
Interlet
Thanks guys. I didn't realise the white switch on top of it can cause the entire thing to stop working... given the motor was just still getting hot, I have a feeling I might get away with just that park switch. 1998 110 300Tdi White Hard Top
Post #647696 1st Sep 2017 10:06pm
