Home > Maintenance & Modifications > Hinge bolts.....?
V8Smith
Hinge bolts.....?
Hi,
We have a Puma 110, loving our Landy, Ive noticed that the bolts rust a little leaving a rusty color water mark each time it rains. Is there an option of Stainless bolts and anyone know the best place to get them. If not any thoughts?
Mike
Post #644241 15th Aug 2017 8:51pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Yes there is and Google is your friend.
Post #644245 15th Aug 2017 8:57pm
V8Smith
Thanks yes I found some, but thought I'd ask as I'm sure there are differing degrees of quality, so any recommendations welcome
Regards
Mike
Post #644247 15th Aug 2017 9:00pm
LR90XS2011
Nak are reputedly the best, speak to Brendan at Overlander.com a sponsor of this site alternatively spray you existing bolts occasionally with ACF50 DEFENDER 90 TDCI XS,
Post #644250 15th Aug 2017 9:06pm
ericvv
Buy new mild steel genuine bolts.
Take old rusty out one at the time.
Clean hole well with a thin paint brush first dipped in Weicon paste.
Replace by a new genuine mild steel bolt dipped in ample Weicon paste.
Any remaining genuine mild steel bolts which are still rust free, also take them out, dip in Weicon paste, and put back.
If you do a search on here with the words "original mild steel bolts Weicon paste" you will get more info.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #644257 15th Aug 2017 9:17pm
Are we talking the Torx bolts here or the hinge pins? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #644262 15th Aug 2017 9:25pm
ericvv
Mike said bolts, hence my recommendation. But if he means rusty hinge pins, I have a different perfect solution to solve once and for all. Whistle
This one....
http://www.defender2.net/forum/topic55937.html
A bit more costly than new mild steel bolts regretfully. Mr. Green
Post #644272 15th Aug 2017 9:40pm
leeds
The Nakatanenga stainless bolt kits are the most comprehensive available in the UK market.
The door bolts are the genuine shape heads. We hear that when people use google and various market places for non genuine headed door bolts sometimes they have to be reshaped!
The stainless bolt kits from Nakatanenga come with anti seize paste as standard which other UK suppliers do not supply.
Available as naked stainless or black stainless.
Brendan
Post #644340 16th Aug 2017 9:01am
^^^^ Very very good too, often corroding OE bolts are a let down to look at on an otherwise brilliant looking Defender.
Had my Nak SS bolt kit fitted fir a while now and no issues at all. Thumbs Up ____\We|Will|Win/___
Post #644385 16th Aug 2017 11:34am
V8Smith
Thanks guys, will order the Nak bolt kit from Overlander today, thanks for the advice.
Sorry for the stupid question, but as a Landy novice, is it just a case of removing each bolt one by one and replacing with the new one of the same length etc, or is there a nut inside the car I need to locate too?
Mike
Post #644470 16th Aug 2017 5:29pm
Most of them have captive nuts, those that don't are on the doors themselves and are pretty easily accessible.
Just do one by one. Thumbs Up
You won't have any issues, easy bolt fit. Thumbs Up ____\We|Will|Win/___
Post #644483 16th Aug 2017 6:13pm
gilarion
Depends if the captive nuts are in good condition but often the mild steel cradle they sit will have rusted and taking the bolt out breaks the cradle or more often than not they move. In which case you will have to remove both bolts and pull the hinge away to either resit the captives or replace, still an easy job though.
If you have to replace the caoptives order stainless steel ones so you will not have any problems in the future.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #644496 16th Aug 2017 6:48pm
