![]() | Home > Puma (Tdci) > Second turbocharger failure |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
I'm not an expert on turbochargers but I would check the oil circuit for the bit and perhaps find out what sort of pressure you should be getting. Puma 110" SW
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
Ok, the turbocharger is fine, the engine is dead. It has to be overhauled, new pistons, rings, bearings etc. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
