Home > Td5 > Strange brake issue with 02' Defender TD5 hard top
Davidarnol
United Kingdom 1995 Defender 90 300 Tdi HT Epsom Green
I have a weird issue with the Brakes on my 2002 TD5 Defender which were working well until recently, pedal then went all the way to the floor before any braking applied, no leaks, pipes / hoses ok, no loss of fluid at master cylinder, bled brakes and everything was fine for a while then same happened again, I changed out the master cylinder, bled the brakes and every thing was ok again, now the same thing has happened again, pedal goes almost all the way to the floor before brakes are applied, still no leaks or loss of fluid, does anyone have any ideas about a potential cause?
Post #641890 4th Aug 2017 4:24pm
dorsetsmith
try pumping brake pedal with engine running and see if problem stop next
re bleeding brake may be air in system still
start with rear passenger side
Post #641893 4th Aug 2017 4:51pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Wheelbearing play can also cause a deeper brake pedal after a longer drive without braking. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #641927 4th Aug 2017 8:39pm
bankz5152
Your servo working?
Test by car off, foot hard on the brake, start car. If it depresses then it works.
The servo can also crack where the master fits causing it to draw in air!
+1 on wheel bearing
Post #641928 4th Aug 2017 8:41pm
Davidarnol
Thanks for the suggestions, With engine off the brake pedal goes almost all the way in before brakes are applied, starting the engine at that point makes no difference to the pedal, no sign of a crack around the master cylinder, (I thought that would make the pedal go solid) bearings are ok,
I will try pressure bleeding tomorrow, Just in case,
Post #641938 4th Aug 2017 9:31pm
VeeTee
Netherlands
Internal leak in the master cylinder - but why would it cure after bleeding? Question Cheers, Vincent
MySite
Post #641942 4th Aug 2017 10:13pm
Davidarnol
The TD5 master cylinder has 3 pipes coming out of it, two front port pipes lead to the front calipers and the rear pipe leads to the back axle where it splits to supply the rear calipers
The rear brake pipe connection at the master cylinder holds pressure when the brake is applied but seems to allow air back into the master cylinder when the brake pedal is released, so everything works ok after bleeding but the master cylinder soon ends up with air in it again, that is my theory anyway, (air is always at the master cylinder, never down at the wheels!) I will change the pipe out to confirm, has anyone heard of a brake pipe union only leaking in one direction??
Post #642214 6th Aug 2017 12:45pm
