![]() | Home > Technical > Getting harder to get into gear........ |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
In the 8 or so Defenders that have been in the family we've not had any gear selection issues, so I'd say it is unusual.
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Can this be done with the box in situ or is it a removal job? I do not have access to a pit or lifting gear
JD 2008 TDCi 2.4 XS CSW |
OK just got back from the garage for an evalulation/estimate.......
He thinks its not the bias springs as its intermittent, it was absolutely fine driving it to and from the garage, he thinks a spring has come loose on the clutch plate and is sometimes in postition, and sometimes loose, he wants to replace the clutch and a few other bits as he will have the box out for about 700 quid........ YIKES Does that sound plausible/likely ? 2008 TDCi 2.4 XS CSW |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
I had the same and it was clutch spring out between friction plate and flywheel partially
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
Ditto!
