![]() | Home > Td5 > Ashcroft 380 gearbox |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3358 ![]() ![]() |
Have you tried changing the oil? It could go on for years like that.
Mine used to make what can only be described as a screaming noise at certain motorway speeds. l changed the oil (the level was a bit low but not much) and it's never done it since, 30,000 miles ago |
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
worth a go with Active 8 as well brilliant stuff may give you a year or 2 more
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
I'll give it a try fellas, as that would be a cheap fix & see how it goes.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Sounds how mine went, it will last a few months but slowly get louder, I changed the oil as well but no difference as it is a bearing failing. A known R380 weak point.
I fitted a Ashcroft gearbox and I am happy with it, this was 18months ago. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6024 ![]() ![]() ![]() |
My box went from whiring to clunk. Dead.
Ashcrofts gerabox fitted. In hindsight I should have got the 5th gear cluster changed as well. I also took the chance to get various parts of the box upgraded 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Thanks for all the info lads.
Obviously it's on its last legs so time treat it to a new box by the sounds of it. New Ashcroft box & clutch it is. ![]() |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
My rear support bearing collapsed at the start of this year so had a new R380 from Ashcrofts which I'm very pleased with. Took the opportunity to upgrade to the v8 5th gear ratio and HD support bearing at the same time
